That is all it takes to stop having to use the terminology.i wouldnt imagine you have used the terminology you have only been qualified a few weeks
Everything is a thingy now!
How would he do that? Bang an earth rod in away from the house and use a multimeter?OP: before you attach anything to any side... first test to make sure there is not 240v running through it... and I don't mean by licking your finger and touching it
So supplier side of the meter first then customer side?Upstream /downstream, when connecting, reverse when disconnecting
Must admit they laid in my toolbag gathering dust till they fell apart!
Interestingly though I did once disconnect a meter union and see a spark jump across, still here though
Doesn't matter if u get it wrong mate , they seem to pass any one these days
Bonding in TN-C-S installations can carry a substantial current even if there is no fault.but in a pme situation with a broken neutral, the bonding could be carrying most of the neutral current
