Hi there, thanks for your time.
So Ive had the first fix electrics installed in my kitchen the electrician is coming out to fit the second fix sometime next week on a labour basis only I'm supplying or rather buying the sockets etc ready for him to wire up and sign off.
Ive attached a rather rubbish paint diagram of the sockets I'm unsure about.
So the cooker is going to be hard wired to a socket directly behind the cooker. From there it will run to an isolation switch above the work tops. From there is runs directly to the consumer unit.
The hood is going to be run via a 3 pin plug to the socket above again with an isolator above the worktop. The hood wiring is apart of the sockets wiring ring.
My thinking is behind the cooker I will require,
MK 45A Cooker Connection - http://www.screwfix.com/p/mk-45a-cooker-connection-unit-white/16686#_=p
The hood socket Im presuming will just require a standard 13a single socket as its via a 3 pin plug - http://www.screwfix.com/p/mk-13a-1-gang-dp-switched-plug-socket-white/14790
Im struggling now as to what isolation switches I need. I cant seem to find any 45a single socket isolations switches made by MK.
For the hood isolator is this okay -
http://www.screwfix.com/p/mk-13a-dp-switched-fused-connection-unit-with-flex-outlet-white/13479
The socket will be 13a and the isolator 13a so presume this will suffice?
Any advice appreciated folks. Im hoping to pick all the bits up tomorrow. The sparky isnt on the end of the phone on weekends otherwise Id have asked him.
Cheers!
Cheers!
