Moving boiler cost?
6 Jul 2017
Moving boiler slightly higher from where it is. Cost?
it's just copper work, extending exsisting pipe work, core drilling new hole for flue. Any quotes?
Thank you
No one can give you a sensible quote without seeing the job
There is virtually the same amount of work moving a boiler as in fitting a new one. To fit a new one the charge is usually between £300 and £900.
Did you think it would be about £50 to give you more work surface underneath?
But it is hardly worth moving a boiler which is more than say 4-5 years old and a current efficient model.
Tony
Tony
Hi tony
The boiler is 8yrs old & yes I do need it to give me more work space under it. It's wasted space due to the boiler being in the kitchen. Not sure how to get around it without costing me a fortune
Hi tony
Look where the flue is outside and see if raising it the required amount would be an issue. Roof line etc.
It's a ground floor flat.
This is a picture to show you
