Hello. I want to put in a small, LED up/down light by the back door. I know how to do this and I have the equipment to do it, but I've not been able to find a clear answer on which type of cable I should use.
My current idea of the set up is this....
- There is a socket near the back door. Spur from this with 2.5mm T&E up to a switch.
- The switch will be fused with a 3A fuse.
- Wire then goes from the switch to the light, which is only LED and will not draw a great deal of current/voltage.
My question is whether or not the 2.5mm T&E is an acceptable from the switch to the light. Some have said yes, some have said use 1.5mm instead.
Can anybody advise whether or not 2.5mm cabling would be safe/acceptable at this point?
