Hi, my son bought string lights for outside ,on the box it says indoor & outdoor use ,
but i'm a bit worried how they can be safe if not low voltage can these be left outside for good
thanks in advance
But usually the lights are OK for outdoor, if that is whah it says.
Do these plug direct into the mains, or is there a power supply too?
If so the power supply will usually only be for indoor use.
So the lights will work until frost/UV/ mechanical damage or general failure means you need a new set.
sorry can't get a photo till the end of the week ,but from what i can remember there is a
basic 3 pin mains plug just along from that a small box ,i didn't have a good look at the time but believe it may be for the light settings ,will have a good look next time i'm at my sons
That will help. There's lots of variations.
If there's a control box the plug may actually be a combo plug and power supply.
Will wait, with bated breath.
