- Joined
- 28 Jun 2015
- Messages
- 17
- Reaction score
- 0
- Country
Hi folks, our existing old-skool Creda electric cooker is on its last legs, and just so happens that my brother was getting rid of his nearly new Belling cooker as he's having a new kitchen.
The existing cable connecting to the Creda is 6mm (says so on the outer sheath). The new Belling oven says 4mm cable on the connector block at the back of the oven.
Might be worth mentioning that the new Belling oven has a lower kW.
Is it ok to use a bigger cable than specified? Load wise, I'd assume an over-specified cable isn't a problem, but my concern is whether the connections will tighten up correctly.
Length of cable from cooker switch to oven is about a metre. From board to cooker switch is approx. 15m.
ps, sorry, wasn't sure if this should be in the Electrics or Appliances forum.
