'tis but a few minutes work to calculate how long a 3kW (max) heater will take to raise Xl of water from Y°C to Z°C assuming no losses.
I would imagine there are great losses having Xl of water in basically a huge bath covered with a bit of expanding foam outside 24/7'tis but a few minutes work to calculate how long a 3kW (max) heater will take to raise Xl of water from Y°C to Z°C assuming no losses.
Don't some of these people with more money than sense leave them switched on more-or-less continuously? If so, they would presumably not be too concerned about the initial heat-up time.Well, I worked out an example to see for myself... 800 litres, from 15° to 37° (just picked because it's body temp), with a 2kw heater, would take 10.2 hours!! ... With real world losses, it's not going to be quite what people had hoped for!
so you probably should have calculated on the basis of 3kW
Oh. Interesting. I wonder why?Both the models mentioned have a 2kW heater.
Proper hot tubs are designed to be left on 24/7, but they have decent amounts of insulation in the sides/base and a very thick insulated lid.Don't some of these people with more money than sense leave them switched on more-or-less continuously?
That makes sense. If they are well insulated (and used reasonably often) it might even be more cost-effective to leave them on 2/7 (a bit like the decades-old immersion heater debate!).Proper hot tubs are designed to be left on 24/7, but they have decent amounts of insulation in the sides/base and a very thick insulated lid.
That makes sense. If they are well insulated (and used reasonably often) it might even be more cost-effective to leave them on 24/7 (a bit like the decades-old immersion heater debate!).
So they're a warm bacterial stew of exfoliated skin, hair, grease, grime and bodily fluids.Proper hot tubs are designed to be left on 24/7, but they have decent amounts of insulation in the sides/base and a very thick insulated lid.
That does, indeed, seem 'obvious' - but, as I said, there have been decades of debate about this (in relation to domestic immersion heaters), amongst people who are not all totally daft - although I can't currently recall the various arguments.It is never more cost effective to leave anything on 24/7. Maximum losses are at the working temperature. Any period at a lower temperature, however short, will result in less overall losses.
