Bricklaying on your own
Won't take long for 9mm MDF to turn into 18mm LDF when it's in contact with moisture!
expert level
I think my brick laying career is over now.
I pulled the old window out, bricked it up and put the new one in. It's looks ok from a long distance. A proper Bricky is doing the front in about 4 weeks.
Well the bricky ran over on his last job so didn't come, then the roofer had a job cancelled so came early which meant I had to lay more bricks.
This weekend I need to replace a couple oflingels and do s couple of rows of brick and block.
It's snowing outside so I'm a bit paranoid about frost.
Should I add a frost proofer and what effect will it have on my mortar?
Mortar sets by a crystalline growth reaction in the cement, which is unfortunately slower than the crystalline growth of water crystals when water freezes; if the water in your mortar freezes it expands and weakens/breaks up the curing mortar, meaning it may never cure and harden properly. In these weather conditions if there's a risk of frost, add something to counter it, dosing instructions on the pack. Frostproofed mortar isn't quite a strong (all additives have a detrimental effect) but it's a lot stronger than mortar that froze while curing!
Thanks, I'll go and get some (y)
Do I still use the plasticiser with it?
Soldiers over a steel lintel.....:eek: As tough as it gets.
Gently prop the lintel.
Make sure all your perp' joints are full.
Your bricks will try and tip forwards so don't bother using a line. Rather, lay all the bricks a upright as you can, then once all the perp's are well and truly full, you should be able to tap the bricks back to upright, using a long straight edge.
Cuts facing up.
