- Joined
- 24 May 2016
- Messages
- 3,961
- Reaction score
- 779
- Country
Don`t see #14, you talking about part J optional for connecting a handbasin?#14 I think.
Looks like I just need to reattach and tighten.
They used to come all assembled, looks like more time saving cut backs in the factory then. No big deal as it can only go on one way and if memory correct there is a little line up cut out and lug to guide you. If using the basin connection then just cut the last 5mm or so off where the line is. (nice and square mind you).It's the elbow siphon.
Photo#1. Look at it carefully and it is stamped up for size of pipe, think you will find 28 & 32mm so slice the smaller section off with a new blade.These are the parts causing issues.
Waste outlow with 32mm dia and sink inflow with 40mm dia. Neither work with U.K. Solvent weld.
View attachment 136164 View attachment 136166 View attachment 136167
wait til its blocked and you digging around in itI don't really want to be using compression on a waste pipe that handles human slurry under pressure !!!
Photo #2 Is for the basin connection and is optional as discussed, low pressure inlet connection (for 32mm not 40mm from a basin)and rubber will compress with a jubilee clip.
Photo #3 Shows the floor brackets and all the jubilee clips you may need along with other bits.
Re photo #1 it doesn't have that stamped on it and there is no configuration that will except a 32 mm solvent Weld pipe. Which has a 36 mm outside diameter.
Hugely annoying!
Hand on heart that is 32mm solvent weld pipe with O/D of 36mm and no I didn`t "stuff" it in I worked it in bit by bit until the pipe was in by 15mm, if you can`t get it in without distorting the rubber, soak it in hot water for awhile then put it on the pipe and if you look up the other end of the rubber part as per photo #3 you can see when it is fully in and nicely square to the pipe. Yes it is tight for a reason!Thanks !
So to be clear the solvent weld pipe has a 36mm OD and the adaptor 'hole' 32mm and you just stuffed it in?
I just did that and the adaptor distorts a little and is very tight.
Aren`t they pictures in colour? It used to show a picture with pipe sizes and where to cut the connector saying that I walk away from Compact installations if I can`t convince the customer to go for a standard toilet with a stand alone Saniflo pump behind.I think I'm convinced!
I do appreciate your feedback.
Makes sense as I was wondering how no one could understand the issue so maybe there wasn't one. The instructions could be better....
CartoonsYes cartoons but could do with some words...
Do you not fit them because they are fiddly?
