- Joined
- 17 May 2012
- Messages
- 11,240
- Reaction score
- 955
- Country
I have an old fuse box that has a working RCD switch attached. It has tripped a few times already, so I know it is working. Once with a faulty socket, and once when I touched the toaster with a knife ....
But, I want a new consumer unit so I can more easily manage the electrics myself. I don't, and won't, do anything major, just changing light switches, fittings etc, myself, without having to turn off all the electric.
So I had an electrician come round, and he said, no, won't just change the box as this might result in it tripping all the time and cause more problems. Recommended we had a £200 survey to determine the state of the electrics and possibly rewire.
It looks like the electrics have been rewired, I saw good cables below floor, and the loft has neet good cables running along joists etc. Not old knackered ancient cables. There are a couple of light switches that need updating as they have no metal backplates or earth, but most of the house (which is small) looks good.
So, was this electrician just hoping to get a load of cash (he mentioned £4000 re-wire, then £1500 if not as bad as it might be) and this in addition to the £200 test, and I quickly lost interest and sent him on his way.
I have a bungalow, some electrics under the floor, some cables running through the loft. Will be decorating it all over the next year, so don't mind if I need some parts rewired - that is, happy to have cables chased into the sold walls and filled over etc.
So, should I just get somebody to install a new consumer unit and hope for the best? I don't think I have many circuits at the moment. Probably just lights, sockets, oven, boiler, and maybe outside lights. I don't like touching these old fuse boxes though, as I have no idea how they work!
