You are ignoring the fact that a copper conductor is also captive within that terminal.Is the gland not made of the same material as an earth terminal?
Delightful.I don't have the confidence that you understand how to interact with other people on forums and would strongly urge you to **** off
What difference does that make?You are ignoring the fact that a copper conductor is also captive within that terminal.
Copper and steel in the same terminal will react with each other. I already pointed this out.What difference does that make?
With reference to the galvanic table, please explain the relative difference between the corrosion which occurs with copper/galvanised steel vs brass/galvanised steel.Copper and steel in the same terminal will react with each other. I already pointed this out.
I realise that you are not an Electrician @ban-all-sheds but every Apprentice-trained Electrician knows of the dangers of combining dissimilar metals. Indeed they will have been taught this as part of their theory.
You are a danger to yourself and other users of the installation. It is clear that you do not know what you are doing.It's not rocket science though is it. All I've got from this so far is that I need to fit a £2 part to each end of the cable with very easy instuctional videos on YouTube. Looks like I'll just have to buy one of each type from screwfix and figure it out myself for all the help you've been so far
What's the actual point of you having any (supposed) knowledge if you're just going to sit in your armchair denigrating other posters & add nothing of value / interest.
Hire a competent contractor immediately. Cease and desist from your dangerous DIY.
So why not deal with the questions posed by other people then?You don't seem to be able to comment on any technical aspect of this project
Drilling would be ok as long as you can make a mechanically and electrically sound connection. But that's what the banjo is for. You can earth any metallic backbox with the normal terminal provided. But I'm far from convinced you want any lump of conductive metal outside the equipotential zone but connected to the electrical installationdrill the junction box to put the screw through is that the same for the socket end of the cable too
Indeed.I realise that you are not an Electrician @ban-all-sheds but every Apprentice-trained Electrician knows of the dangers of combining dissimilar metals. Indeed they will have been taught this as part of their theory.
