Hello all
Need some advice, I have builders that are going to install a marble fireplace surround and a separate unconnected gas safe chap who is installing a focal point Eastleigh high efficiency gas fire. The fire surround is this one;
https://www.fireplacesupermarket.co...MIuIaOj8Ka3AIVJbXtCh3LFQsXEAQYASABEgLBifD_BwE
The fireplace opening is from a previous gas fire that was removed. I have been telling the builders to get the marble fireplace installed in anticipation of the gas guy who is coming next week to install the fire, but the builders reckon the fire needs installing first.... I can't get my head around why, as from my limited knowledge the gas fire is pushed back against the marble back panel, am I correct ?
I want to also ensure they will be installing the surround correctly.
The floor in the room is wooden floorboards, is a sand cement mix ok for the hearth to sit on ?
And what should be used to secure the back panel/pillars together and to the wall, tile adhesive? Any other regulations or safety issues that I should be aware of.
Thanks I'm advance.
Thanks I'm advance.
