I've been looking online at a new sink base unit that's listed as having a 40mm void to it's rear? Is it 40mm, or is it actually larger in order to accommodate the compression connections etc? My existing sink waste pipe is slightly over 40mm anyway, with the various connectors being significantly bigger. I don't see how a new sink base with a 40mm void will marry up without some invasive surgery to the unit.
Is the 40mm void measurement only a nominal size that actually means it will be large enough to accommodate compression connectors that accompany a 40mm waste pipe? If so what size would the void actually be?
I have an unused gas valve on another kitchen wall that is 75mm proud of the wall, I'd quite like a base unit in front of it without chewing too much (any) of the base unit off to fit in front of it.
Thanks,
Dain
Thanks,
Dain
