AG6 Sounder and Strobe - no comfort LED’s ???
5 Nov 2017
All wired in correctly and working as it should, LED’s activate when triggered but no comfort LED’s that are visible showing its live and working? (On my other building same spot stem also with an AEG6 the two red alternating LED’s flash intermittently)
Any ideas as to why??
Is battery connected ?
No WHAT does it say in the above installation instructions for the AG6 bell box[/QUOTE
Ok here’s my connections, I’m a bit lost as to where this link is in the AG6? I can see to the left of the AG6 connections “batt”?
So no you haven't fitted the battery link ( picture 2 ) remove from test and fit on battery ...
Ok, so it’s the terminal to the left “batt” should a link have come with the AG6 (nothing in the box) or do I have to buy a specific type of battery with the correct link? Thank you for your help so far .........
FFS ....ITS THERE IN PLAIN ENGLISH .....REMOVE LINK FROM TEST ...PUT ON BATT....JESUS....
Thankyou - I wasn’t aware those links were removable - swapped over and working perfectly - your Diazepam is in the post! ;-)
