- Joined
- 10 Apr 2019
- Messages
- 67
- Reaction score
- 0
- Country
I am trying to decide what is the best / neatest way of rewiring my electric hob 6.6kW and electric oven 1kW. Oven is fitted with a 13A plug.
Current wiring is 10mm from 40A fuse, to 45A isolator switch to JB (which i cant access due to kitchen cupboard) spurred 3 ways,
1. To JB connecting hob.
2. To socket on cable
3. To surface 1g socket for fridge
New 10mm cable installed. 40A fuse will be 40A MCB + RCD.
New 45A isolator.
Fridge moved to socket circuit
And this is where i cant decide the best solution.
I have pulled the hob cable through to the isolator switch with the aim of removing all of the old JBs.
So the oven?
1. Think I cant use 2.5mm from the isolator to a socket due to no suitable fused protection for the 2.5mm cable
2. FCU for the oven spurred from the cooker isolator? Will i struggle to terminate the cables in the 45A isolator switch? Presume I'd have to run 10mm to the FCU which may not fit into the FCU? Any recommended products?
3. Continue 10mm down from cooker isolator to a splitter and wire oven & hob from that? Which product?
4.put oven on socket circuit. (Would prefer to put on cooker circuit)
5. Another option that i havent considered.
Pictures of existing wiring of which all of it is being removed or replaced.
JB to cooker. (Not sure but it might only be a 20A JB...)
Oven socket
Another JB is hidden behind back of cupboard.
3 cables are fridge socket, oven cable/ socket, to hob JB.
1 10mm cable goes up to the cooker isolator.
New chase with old cable off to the right outside of zone. I could put an FCU to the right of the 2g ba k box.
Many thanks!
New 45A isolator.
So the oven?
Oven socket
Many thanks!
