What would the recommended minimum edge distance be for drywall screws?
Thank you
Thank you
I think it's supposed to be 20 for a factory papered edge and 30 for a cut/open edge
The spec sheet has all sorts of information on screw spacings and overhangs presumably used so estimators can price the job.
That sounds logical, bet it never happens on site.
Plasterboard is often joined on the edge of a stud which is 45mm wide -I suppose you might get 20mm if the screws angled a bit and the join is central
