I think it's supposed to be 20 for a factory papered edge and 30 for a cut/open edge
The spec sheet has all sorts of information on screw spacings and overhangs presumably used so estimators can price the job.
47 landing leaves 23.5 max. per sheet edge, with edges of sheets and joists to be steered clear of...tight!
The aussie youtubers with 6m sheets, even sheets with 4 tapered edges seem to have it sorted. Do they always just paint the finished drywall or ceiling? They seem to shake their heads in bewilderment when they see our housing.
Angled heads below surface level, so close to the edge? Doesn't sound right. And spread doesn't like them proud.
Maybe put the ends between joists and pva a splice backing board on, and so avoid putting the plasterboard ends on a joist at all? It might help prevent cracking.
Scrim is fine for the 1st few years but later on they always crack, maybe a splice backer would be better, then scrim over the joint anyway?
Ok. I was asking because my bathroom has about 8mm of coarse plaster over the ceiling plasterboard, with a skim over the top of that (well, the btm if pedantic).
Loving that antipodean 'splice backer' for the taped joints, with the backing splice board stuck with architrave fixative to prevent cracking.
I may just float the ends between joist and pva some splice backers on, ply or plasterboard. I have used ply before now, extending 150mm each side of joint.
