- Joined
- 17 Oct 2017
- Messages
- 36
- Reaction score
- 2
- Country
I wish to have a new cooker hood installed that will come with a plug, so need a single socket installed up high.
Initial idea was to use a vacant single socket above the worktop, change this to an FCU and spur a socket above or in the wall unit adjacent to where the cooker hood needs to go.
But i've just read a thread where they talk of spurring a socket off an existing extractor fan isolator, and wanted to check that this was possible - run 1.5mm2 twin and earth from the extractor fan isolator switch to a single gang unswitched socket and plug the cooker hood in to that?
The extractor fan isolator is on the other side of the room, but I would run trunking up high where wall meets ceiling - there is trunking here already for the fan. The extractor fan is on all the time - it has a trickle mode, and boosts when needed, but is insufficient when cooking.
It may seem a less pretty option, but i have tiling between worktop and wall unit and would prefer not to disturb these running a spur up from the single socket.
Thus wondered if the 2nd option is viable and correct to do?
Thank you
Thank you
