Implications of outer sheath cable damage on household appliance
7 Jan 2010
Yorkshire
We found damage in our rental property recently and determined the tenants have a rabbit and it has been nibbling its way through carpet, skirting and plaster walls. However, it has also damaged the outer sheath on the power cable on the tenants own lamp and vacuum cleaner as you can see in the following photos.
It looks like the vacuum cable has been damaged and patched up a couple of times.
I have discussed the damage with the tenant and verbally warned them about using these appliances without replacing the power cables and I'm just about to put it in writing, however, a quick Google hasn't really found anything tangible about what this kind of cable damage could cause.
It seems to me that the damaged cables could result in electrocution if any of the wire cores are exposed (I couldn't see this) or fire, and it may also affect insurance policies (knowingly using an appliance with a damaged cable).
Am I correct to "forbid" the tenants from using these appliances in my house or am I being unreasonable? Could these cables actually cause a fire and if so, how would this happen?
Thanks for your advice.
Tenants own items = tenants own risk in using them.
Other than warning these people, there isn't really anything you can do.
I wouldn't worry too much about fire.
In your shoes just make sure the house has RCD protection, and it has been tested by pressing the test button.
That should cover yourself I hope
The tenants would have to be rather bloody stupid to not want the flexes replaced. I have no time for such stupidity so I'd just let them kill themselves.
The large damages to vacuum cleaner flex was possibly caused by being mangled by the brushroller.
Thanks guys.
I know it's the tenants own risk, but I wouldn't want the house to burn down, however, I'm struggling to understand how that might actually happen.
Unfortunately, I don't think the house does have RCD protection. It was built in the 1930's and although the wiring has been upgrade, it looks like the original consumer unit, with MCB's fitted, and other bits and pieces, which I suspect have been added over the years (power to garage for example).
I am in the process of arranging a test of the electrics and was thinking about having a modern CU installed, but it depends on cost as we've already spent a lot of money on the house this year.
You need to have the wiring tested now, as well as on a routine basis. There appears to be no RCD protection on any circuit except that one feeding the mineral insulated cable (which I hope is an RCBO!)
The wiring should be tested/inspected every five years or change of tenant, whichever is sooner.
Speaking solely as a Portable Appliance Tester, that Dyson would receive a Fail, Do Not Use sticker. If ANY of the coloured cores of a sheathed cable/flex are exposed, that is an automatic fail.
HTH
I suspecct that your hope is in vain, I can't quite read everything on it, but it looks very much like an RCD with 25A switching capability, I cant see any trip curve indicated. I suspect that at the time that was made (early 90s) that a 25A RCBO would not have been an off the shelf item, 25A remains a bit of a strange rating for overcurrent devcies, rarely specificed and at the time very few RCBOs would ahve been installed, and the mjaority would have been for ring final circuits. Hell, If I wanted a 25A RCBO these days, I'd still probably be in for a few days wait!
Can you elaborate, apart from outdoor equipment use
Where it is needed for fault protection would be at least C2
Most instances where it is needed as part of a special installation or location would be a C2, EV chargers, swimming pools, etc
