That's my point. The soldered joints obviously should not get anywhere near melting point of solder 'in normal service' but, under some (or fault) circumstances, that might be a possibility - hence the 'risk' which you (and I) wouldn't like to take.I'd use a crimp inside personally, I can't imagine the temperature inside the Iron cable points will reach melting point of Solder but wouldn't like to risk it.
Same here. However, although I've had umpteen soldering irons (and still have many of them), none have been 'fancy' ones. In other words, I've never had a soldering iron with any sort of temperature control - and if one leaves such irons on for a while, the tip often gets far hotter than is needed to melt 60/40 solder.
Ah ... my 'oldest one', which was my Grandfather's and is probably now over a century old, doesn't do volts, 50 or otherwise - but it needs a gas stove or similar to heat it upI use a temperature controlled one, I also have a couple of variable output ones and one of those instant soldering guns (useless). My oldest one is faithful 50v ex-telecom GPO one, from when I worked at GPO telephones.
I've replaced loads of iron cables over the years and I feel the 'typical' construction method is to bring the connexions to the handle with heat resistand wire, originally bare wires and ceramic beads but more recently with hard white insulation which feels like it may be part of the Teflon family and then joined to the incoming flex with crimps or screws. Agreed the other end will often be a welded/braised style joint onto the element or thermostat.You will probably find the cable going to an iron element will be induction brazed on a good model.
This is the method we used on HT motors to do the cross connections and fit the leads.
Standard solder seems a bit too easy to fail in my opinion. It may not melt, but I wouldn't be surprised if it got just a little bit softer, leading to a poor joint.
Same here, but I'm not sure I would call it particularly 'small' (upper pic below). I also have one with an even bigger tip which does 'do volts' (it says 240V) - or, at least, it would if it had a lead (lower pic) (with apologies for grotty photo!)I've got one of those ones somewhere. Looks like a little square ended spear.![]()
Ah but the bottom one is electric. If I had to guess I'd go for Solon or English Electric and 150 to 250W.Where did my photo go? Try again ...
Edit: Hmmm - at least it's there now, even if one has to click on the thumbnail!
Indeed it is - as I said, that one "does do volts"Ah but the bottom one is electric.
I might have guessed siumilarly. However, having cleaned it up, and somewhat to my astonishment, on the handle ...If I had to guess I'd go for Solon or English Electric and 150 to 250W.
Sorry John, I completely missed that you did 2 posts.Indeed it is - as I said, that one "does do volts"
The metal shaft is engraved with "230/250 VOLTS Made in England", but I can find no mention of power anywhere. I certainly have used it - the cable was removed because it was getting a bit iffy, and I haven't yet got around to replacing it - but, when I do, I'll measure the power!
