Unplug the dishwasher and cut the plug off.No i'm not a troll, ive been on here a while. Its trying to get it through to my husband that this is serious as he feels I go over the top.
Hi Guys, I lied I am not fine....and I am about to throw my husband out. Just eaten dinner and filled the dishwasher and touched the metal on the door inside, I almost shot across the room, every metal part is LIVE. This shock was even worse than yesterdays as it was all four fingers, its definitely live without a doubt. I am going to be very vigilant with my heart today. But what could suddenly make my dishwasher live, could it be the plug. I've attached photo's of my electric box and wires, my property is rented and everything is modern fuse box wise. The photo's are of my fuse box, my electric meter, the yellow and green wires under my fuse box and the yellow and green wires going to my stock cock.
Yesterday I had my hand on my metal sink when I touched the dishwasher.
It's faulty and dangerous.But what could suddenly make my dishwasher live,
Hardly. That mess is at least 20 years old, has clearly been modified as the labelling doesn't match up with the circuit breakers and is missing most of the required warning notices including the one that indicates the last inspection date. They may have been on the front cover which has been broken off and is missing.my property is rented and everything is modern fuse box wise.
As usual Winston talks sense, something else may be live and you are earthing yourself via the dishwashers earth.
Corrected that for you.
There are also other serious faults with the installation, as live parts should cause fuses to blow / circuit breakers to trip if metal casings of appliances become live.
Touching live parts should trip the RCD.
It certainly looks as if it very probably is.That earth bond is connected to... plastic pipe!
AS has been said, you really shouldn't have let it happen 'a second time'. However, since you did, can you remember what else were you touching at the time you got the second shock? - it's not possible to get a significant shock by touching just one thing.I wasn't touching the sink the second time.
