Fair enough - if the only issue is it's age (hence, for example, non-sleeved pins) - but what about that small defect in the lid - would that be acceptable?It was a discussion on the course I did this week - just because a plug is old does not mean it fails.
While it cannot be reused it can be left and allowed to be used.
No it isn't. It's clearly damaged.Fair enough - if the only issue is it's age (hence, for example, non-sleeved pins) - but what about that small defect in the lid - would that be acceptable?
The plugtop (that's a trade term for the complete plug) in the picture is not the type with a window to check the fuse size. This is an old MK plugtop (that's a trade term for the complete plug) - these particular ones did, however, have a hole in the top where the earth pin is - something new plugtops (that's a trade term for complete plugs) just do not have nowadays.It's a long time since I have used an old plug like that, but seem to remember there was a window so you can check fuse rating without removing the top? It was red = 3A, black = 5A and brown 13A although seen other colours so not 100%.
Where does make a difference, at work all fuses from same supplier so colours always the same. However I have opened up plugs to find wrong size, but that can only happen by manual intervention, a fuse does not over time change from 3 to 13 amp, so if looking for manual intervention where would you stop?
This is an old MK plugtop, these particular ones did, however, have a hole in the top where the earth pin is.
Yes, a slot then. I have heard it was for bonding some equipment.More of a slot i recall, what was it actually for, was it to connect an earth bond into.
And its not PAT testing eitherThe plugtop (that's a trade term for the complete plug) in the picture is not the type with a window to check the fuse size. This is an old MK plugtop (that's a trade term for the complete plug) - these particular ones did, however, have a hole in the top where the earth pin is - something new plugtops (that's a trade term for complete plugs) just do not have nowadays.
Quite so, it's PA testing - not to be confused with testing public address systems.And its not PAT testing either
2A, 7A and 10A are black too!black = 5A
