600mm wide soffit boards
27 Sep 2010
I'm looking to replace my soffit boards.
They are 600mm wide! The vented soffit board is expensive at £100 for 5m (need 3 lots). Will probably cut them into 2.5m sections and fit with H bars.
Is there another way of doing them? Some neighbours have the interlocking boards laying the other way but it doesn't look great. Would they be glued together with mastic?
Any other options?
I'm doing exactly the same right now.....I did consider plastic but went for 6mm hardwood ply instead, screwed on. I'm painting them Sadolin Rosewood stain but I can't get the stuff at the moment. Purely cosmetic for me.
When I'm done I intend to fit plastic soffit ventilators, 76mm I think they are.
Mine, like yours seem to be, are asbestolux so I didn't disturb them more than need be - at least you can see where the original nails are which is good for fixing.
John :)
Any other options?
Use hollow soffit and J-trim and go in the opposite direction to the fascia. Looks a gazillion times better too. It's quite difficult to try and fix long lengths of floppy sheet without 7 pairs of hands, especially if you are guiding it into a recipient trim.
Yes about 600 wide (measured them), monster soffits!
Thanks Noseall - good point about the length of the boards. I would have had them cut to 2.5m each to fit in the car but its still a long bit of wobbly board to fit!
I did wonder if they were asbestos! How will you drill the holes for the vents without disturbing them? Most of mine are not nailed - just sat there!
Im hoping to have an extension built across the back so looking for a long term solution. Would painted wood last a long time?
John :)
Also the current boards are just sat on the fascia return and the bricks - they are not fixed at all. Could I just silicone the hollow boards on?
Regarding the vents, I’ve bought the correct size holesaw from B&Q so I’ll drill up through my ply and through the 6mm asbestolux behind......there will be a bit of dust but I’ll wear a mask.
I don’t understand how your soffits are fixed......my own have a bearer on the back of the facia and another fixed to the roof timber. They are fixed with galv clout nails, 1”.
Regarding longevity, the facias take much more hammer than the soffits......like yours, mine are well overhung so don’t get any weather. When I restored this place in 1987 I fitted new facias and the soffits took some damage which is why I’m cladding over now. Treated with Sadolin, the facias have been great and still are but I’ve had to replace the odd length due to the 18mm ply delaminating.
I did consider plastic but I work on my own and they would flop about all over the place......hence me using 4’ lengths of 6mm ply.
John :)
No. They need to slot into a J trim against the wall and are normally wrapped by a fascia toe (when overlaying the fascias with cap). You may be able to J trim both ends of the soffit pieces as the seem long enough to flex into place. You then fix self drilling screws (same screw you fix the J trim with) through the dedicated fixing lip on the hollow soffit.
True, they dont get much weather at all.
the boards are just sat there. One end on the top of the bricks. The other rests on the lip on the facia board. I guess if I slot the hollow plastic underneath it wont go anywhere!
John :)
Just hung out the window and took some pics. The boards are not fixed house side and rest on the bricks / top of the windows. They are somehow fixed at the facia board. Will investigate further once the weather cheers up and get the scaffold tower back out!
Any thoughts on fitting new soffit boards to this? The current soffit slots into the facia board via a groove and then sits on the top of the bricks!
This is how I did it in the end...
