I bought a Hive active heating system to replace the current set up which is the EPH wireless receiver WRS1i for my Worcester Combi boiler. I thought (perhaps stupidly) that the set up would be easy and I could avoid a BG install! When I opened the EPH receiver I realised I'm actually not sure what to do - the L and N are straightforward but I see multiple (3) Live wires so I'm stumped.
There is a wall mounted thermostat which has never worked and is wired in the current set up (pls see pic) but as its no longer required - I would appreciate any advice on what needs to be removed from the existing circuit and what should go where (given the current wiring) when installing the single channel Hive receiver?
Any help would be much appreciated!!! Many thanks
