Extractor fan question
30 Aug 2019
So got an inline extractor fan in the loft. 3 pole isolator fed from a ceiling rose (line loop N + E). Orange light on isolator comes on and cables to fan are live, but fan doesn't run.
All the JB's in the loft are in old metal conduit, and all black + red wires. The bathroom and a couple of cupboard lights have been fitted more recently so there is 1mm T+E to them and that's where I found the ceiling rose, but got a feeling something isn't quite right somewhere.
I'm going to wire a flex to the fan and plug it in to make sure it's working but after that I guess it's got to be a wiring configuration issue with where its connected to at the ceiling rose?
Michael
save up. When you reach £12, buy a multimeter.
use both prongs.
Test across the N to the L, and the N to the SL.
Then, test again under load.
save up. When you reach £8, buy a multimeter.
use both prongs.
This is on the list of testing things today. I do have a multimeter
So funnily enough I can't find a permanent live at the ceiling rose. There's only 240 if the light is switched on...
Can I take a perm live from somewhere else in the loft?
show us a photo of the ceiling rose please, open, to show the wires.
And inside the box where the light switch is.
How old is your house?
Will do the photos shortly. House is 70s.
Just for sanity, if I want the fan (timer version) controlled by its own pullcord and not at all influenced by the bathroom lights, do I have to run a T+E from a ceiling rose or JB in the lighting circuit to a triple pole fan isolator switch, and 3C+E from the isolator to a switch/pullcord operating the fan?
Sorry if I'm getting it confused. Appreciate the guidance!
2&E to switch, then 3&E to isolator then fan.
SL only exists at and after the switch.
But I think switching by light switch is better. Some people have an aversion to ventilation and will not turn on the extractor until water is streaming down the walls.
Yeah I hear you. We have a massive bathroom window with so never need the lights when having a shower so prefer a separate switch.
Pullcord for turning fan on and off would be best. What kind am I looking for? I keep seeing triple pole fan isolator ones, is that right for this application?
If 2+E going to switch, and 3+E coming out, does that mean you must add a loop wire from L to SL on the supply side of the switch?
Thanks so much for help so far.
There are several ways of routing the wiring depending on what you have at the moment.
To add a separate switch for the fan, you need the cable from the switch connected to a Permanent Live and the existing Switched Live to the fan which has been disconnected from its present switched connection. Neutral remaining the same.
It matters not where these connections are made - at light, isolator, fan or unnecessary junction box.
That makes sense, thank you.
If I'm running 2C+E to the switch, then 3C+E from switch to isolator, should I take a loop wire from the live to the switched live in the switch, so that the output of the switch has both live and switched live?
Thanks all!
