- Joined
- 10 Apr 2016
- Messages
- 20
- Reaction score
- 0
- Country
During kitchen replacement I've accidentally drilled into a ring main cable (stupid mistake!!). The cable is buried in a very solid external wall so pulling it out and replacing with new cable is not a viable option.
I plan to repair it by re-routing the cable to an adjacent spur and incorporating it into the ring (see green lines in diagram below). Then the current ring socket would become the spur. The existing spur is on a plasterboard wall so would be much easier to chase new cables to/from. I'd cut the damaged cables then leave them buried dead in the wall.
I am thinking of using one of these https://www.tlc-direct.co.uk/Products/ASJ803.html to join the cables. It will eventually be underneath a shallow kitchen cabinet. Not technically inaccessible but seems a compact solution for joining 4 cables.
My only concern is with the JB being at basically floor level (attached to the wall underneath the cabinet) in case of a water leak/flood. I am not aware of any regs on JB height so I might be overthinking this? If it is an issue I could put the JB closer to the previous socket, higher on the wall, but that would mean replacing more cabling (and it'd be behind a washing machine).
I know ideally I'd re-do the circuit with uninterrupted lengths of cable and not use a JB but as this socket is the last on the ring and it's a fair way back to the CU that won't be feasible either.
Can anyone suggest a better way of doing this or would this approach be OK?
Thanks!
Thanks!
