D
dontbelieveawordofit
you think you have free speech? wake up. you will say what you are permitted to say.years ago when worked on the railway as a driver [about early eighties then] i used the term packies not realizing it was in any way derogatory indeed if i knew it was in the least negative i would be horrified as i dont do negative to any great extent never mind in an evil way ??
any way the people concerned understood i had zero negative intent so was taken in the way ment as it should be
in that respect i was Nieve and wrongly informed so iff your intentions are to be offensive or possibly evil your words are wrong and need correcting including a penalty or punishment
iff you intentions are misguided with no ill intent or upset meant then no penality should be applied if a correct heart felt genuine apology is given when you realise it can be wrong and upsetting even if it takes several times till you remember
any way the point i am making if your "free speech "is being offensive or possibly evil it deserves being rained in with a heavy hand
if it is nieve or well ment a lighter hand should be used
