- Joined
- 17 May 2012
- Messages
- 11,341
- Reaction score
- 988
- Country
Looking good Jonbey. Do you have a ladder for getting in and out?
If you put a drainage hole in the middle it will defeat part of the purpose of fitting a cover.
Covers are great for keeping leaves etc out of the water, but they should also be able to cause rainwater to run off rather than mix in with the pool water.
The only way I have found to do this is to put a gazebo over the covered pool, which also stops dead flies/insects getting drained in if you put a hole in the cover.
Has it filled up yet? How are you getting on with your pump and heater?
Got a ladder, need to build it. Over half filled, so not been able to test the filter and pump yet. Hopefully by the afternoon it will be ready.
