Currently have a converted garage with a door at the back that leads into the Kitchen. We are looking to block up this door for a Kitchen renovation & move the door to the foot of the stairs.
The ground floor wall is a single block wall with plasterboard either side & supports the joists for an ensuite bathroom (& possibly separate joists for the bedroom above garage - but I am 80% sure these joists run the length of the room instead of the width - plan to check a neighbours garage who does not have a converted garage) & Once above the joists the wall for the 1st floor is timber & plasterboard.
Just wondering if this is a specialist job, or if a competent DIYer can do it?
If the later, is a Lintel like below OK, or do I need a structural engineer?
https://www.wickes.co.uk/IG-Ltd-Internal-Steel-Lintel---1200mm/p/220067
