Looking for options for covering a service passageway that runs between house and our neighbours - it is a dead end. Passageway is currently open (no roof) so rain can get in but there is little light /ventilation to dry it out.
Passage is:
Min height at open end is 2.85m
Rain water drain at CLOSED end of passage - DOH!! Drain currently services two small areas of the house roof and the uncovered passageway (that I'm describing)
Passage is service access for roof, guttering so would be good to be able to stand on/work on roof.
Passageway has two room windows facing into so want to maximise light (one window on closed end, other on one side)
Property is Victorian but passage is tucked out the way so limited restrictions on appearance.
Roof options?
Had considered a pitched tiled roof with Velux style windows (Longer lasting, pitch increases daylight, opening windows for ventilation, awkward to work from?, limited daylight due construction?)
Flat roof with roof light (good to stand on but limits daylight as not sloping)
Polycarbonate pitch roof (ideal quick fix as allows light, no need to dress underside but no service access). Seems to be a long span (3.7m) as most polycarbonate sheets seem shorter?)
SUGGESTIONS PLEASE?
Passage is:
- 3.7m long
- 1.3m wide
- Surrounded on both sides and one end by 2-storey buildings
- Open to light at one end
Roof options?
SUGGESTIONS PLEASE?
