Silly RF Lighting
31 Mar 2006
Leeds
Spot the ‘deliberate’ mistake :mad:
I suspect that many others will feel your pain, having done it themselves.
At least you remembered to put the boot on :)
Id quess a pyro supply and fp for the 12 or 24v stuff.
Though, can see a open Galv socket but dont see a double pole isolater marked FIRE ALARM DO NOT SWITCH OFF
Ooops!
Having learnt a similar lesson many years ago... when a terminated a 256 pin harting connector onto an audio multicore.... I was so happy with myself.... until I spotted the shell still on the bench - grinning at me!
I feel your pain RF!
At a much lower, hence less catastrophic, level, there used to be (haven't seen one for years) those wretched BS1363 plugs with a 'plug top' (correct usage, for once :-) ) with a hole through which the cable had to pass. I can't remember how many times .... :-)
At a much lower, hence less catastrophic, level, there used to be (haven't seen one for years) those wretched BS1363 plugs with a 'plug top' (correct usage, for once :) ) with a hole through which the cable had to pass. I can't remember how many times .... :)
Yeap, done that! And also BS4343/Ceeforms ...... its always when trying to terminate them in a hurry on a festival site..... the 125A 5 pin ones are the ones which make you cry!
Rf, are smaller pots and seal etc easy to get nowadays, last time i tried about 10 years ago it was a struggle though it was i think 16mm 2 core
They seem to be getting more expensive, but I don’t have any trouble getting 2L1 to 4L2.5 which is all I really use.
Not sure about something as big as 16mm that might be a bit rarer these days.
thats when sidecutters come into play..........
