Bulb melted socket after installing dimmer switch
5 Oct 2014
Hertfordshire
Hi all,
I have a plain and simple 100w max light fitting in a spare room. I am just about to renovate it to be a nursery so thought it would be a good time to install a dimmer switch.
The fitting originally had a 100w bulb which I found hummed a lot. After some googling I found this was not unusual and could be resolved by using a lower watt bulb or by trying a 'rough service' bulb that has a thicker filament and less prone to vibration which makes the humming.
After some hunting around the house I found a 60w rough service bulb and gave this a try. It resolved the humming perfectly, but I found it to be a bit dreary in the room so wanted to try a 100w rough service bulb.
I order a 100w rough service bulb and just tried it and although there was a little bit of humming at certain levels of dimness, it was much better. However, after 5 minutes or so I could smell burning and noticed that the bulb had actually partially melted the plastic on the light fitting.
I did notice that the new 100w bulb did seem exceptionally bright. I am sure it was brighter than the previous non rough service 100w bulb I had before installing the dimmer switch.
What is going on here? Did I get a bad bulb? Or is the dimmer switch not compatible and is somehow suppling more power than it is supposed to?
fault bulb.
or poor contacts on the holder and/or bulb I think. make sure they are shiny before starting again
Yeah, that's not a huge problem. I only bought a cheap dimmer switch so don't mind replacing it.
I am going down a bit of a wormhole looking at my options. I see that some of these LED units come with thier own remote control allowing you to dim, change colour etc. I had no idea there were so many options!
The dimmer switch can't do this, but one of your other comments :
Rough service lamps are usually dimmer than their non-rough service friends... any chance you may have purchased a 110V lamp????
That would explain everything!
It's a 100w/110v lamp.
I thought that as long as it is 100w (which is the max for the fitting) I would be Ok?
Don’t do any more DIY electrics until your knowledge is massively improved.
Ok crap, I just read up and have learned something new.
Can't believe I have gone this long without understanding the significance of the voltage rating on a lamp.
Embarrassing
I guess I have just always picked up a bulb from the shop which are always standard 240v. Now they are quite hard to get hold off I didn't check this.
Lesson learned
Ah, now everything makes sense!
No. A 110V lamp is not suitable for direction connection to the UK mains. The UK mains is 230V. As a result the lamp would have seen a voltage much higher than designed, in fact operating at approx twice its design voltage would mean it drew around 4 times the power... it would be more like a 400W lamp. Hence why you observed it to be very bright & very hot.
This lamp is really intended for a building site which uses 110V lighting for safety.
*Cringe* Thanks again
No I'm afraid not, it doesn't work that way.
A 110v 100W bulb will be running at about 440W or in round terms more than 4 times as bright.
The average fan heater will be around 2000W to 2500W so the amount of heat given off by your bulb is somewhere 1/6th to 1/4 of a room heater, so yes it will be very hot and cause a lot of heat damage.
On top of this rough service bulbs tend to be a yellower light and not as bright, accordingly the reduction of light output means some other form of output and this will be in the form of heat. In other words a rough service bulb is usually hotter than an equivalent standard bulb.
EDIT:
I started writing this reply just after message #9 was posted and didn't see the next 4 before posting.
If this hadn't been a rough service bulb, chances are it would have blown quite quickly, possibly instantly.
One firm I worked at kept the 110V and 230V 500W halogen lamps next to each other in the stores. I think everyone who worked there at some point grabbed the wrong voltage lamp and put it in a 230V fitting.
It went with quite a bang when I did it :LOL:
