Is there a white plastic switched 3 gang that will go straight on the old 4 gang back box?
30 Mar 2012
Monmouthshire
Converted car port to domestic use, it had a single light, switched at a 4 gang just inside previous front door.
This new room has a new supply arrangement, and new light switch inside the room, the previous switched supply is obsolete.
I'd like a 3 gang 2 way switch to replace the old 4 gang 2 way but back boxes seem to be different sizes.
The old 4 gang back box is a bit crowded and there will be a few obsolete wire ends to terminate properly so space is an issue..
Is there a white plastic switched 3 gang 2 way that will go straight on the old 4 gang rectangular back box? It would be handy if I didn't have to change back boxes.
Or even a 4 gang with removeable switch/blanking insert arrangement to go straight on the old rectangular back box? Does the creature exist?
Mk normal grid switches would fit
3 or 4 Gang both fit the twin size box
and sold in screwfix
You will need an earth at the switch though
https://www.screwfix.com/c/electrical-lighting/grid-wiring/cat830532?brand=mk
82380_P
Personally i think that click cover looks ugly
Varilight also do normal type non grid but in metal finish
https://www.google.com/search?q=3+g...0i22i29i30.15122j0j4&sourceid=chrome&ie=UTF-8
Surely there must be normal switches that are the same size.
One would think so, but the great majority of 'normal' 3-gang switches appear to be 'single box' sized, whereas I assume that the OP's 'rectangular' box is 'double'..
82380_P
I did find these but you got there 1st.
The 2 gang switches available are 10amp and 20amp? They're for the hallway & landing lights, is a 20amp rating required?
Oh yeah forgot about MK grid. They do look nicer than click imo.
You only need 10A switches for a domestic lighting circuit.
One does - but, from the OP's point of view, there would be no harm in having a 20A one as per the linked MK gridswitches.
The single pole are cheaper but I wouldn' know the difference?
The OP?
