How to join a solid wood worktop
15 Jan 2021
I would like to join some solid wood pieces together to make a desktop.
I have some left over pieces of solid oak wood top which had previously been cut into pieces (don't ask). I would now like to use the wood to make a desk. My question is what is the best way to join the pieces together to create a solid desktop which I can attached legs/frame to to make a desk?
My first obvious thought was glue but assume this would not be strong enough. What is the best way to create the solid desktop? I have very limited woodcrafting skills and tools.
Can I suggest a look @
https://www.youtube.com/results?search_query=making+a+worktop+from+planks
In there you will find a load of clips that will give a good heads up.
One way is to joint the edges of the boards with a "Biscuit Joint System" + a decent wood glue.
Can I also suggest you organise your boards as Wide, Narrow, Wide Narrow, Wide.
You will also need some method [there are several] of "Cramping" the boards up tight together.
Ken
Ken
Perfect thanks Ken!
Found a very useful video and also now know there is such as a thing as a dowel jig which looks like something within my capabiities
Many thanks
Wood glue is immensely strong, and biscuits are more for alignment than being required for strength. Clamping them up properly (having evenly spread the glue) is the most important thing.
I would stain the narrow strips before assembly to give it some visual interest, and make a feature of the fact that it's 5 strips of wood rather than trying to pretend it isn't.
one other small thing is try not to get the glue on to the face of the timber, it may stain the surface, OK not a lot but??
Thanks for advice everyone. I have purchased a dowel jig as following a video on YouTube looks like a job which is (hopefully) within my skill set.
Any advice on which glue would be best? or will any decent wood glue work
Also, I am swaying towards a wood stain rather than varnish. Any good brands I should look out for. I swear by Liberon for my desk stain
As for Glue?
Suggest you look @ titebond?
There may be other suggestions that pop up
You'll be needing a set of sash clamps for this. You can buy just the heads and then bolt them on to some basic sawn timber and they'll come in handy for other jobs too. (They can also be mounted 'back to front' for pushing apart rather than clamping together). They used to sell these in machine mart, but I can't see them right now.
Nozzle
The easiest thing to do is to put a couple of strips of wood underneath and screw the planks on it.
Using the correct length screws from under what it will be the desk, it will all look neat.
Then of course biscuit joining would make it perfect, dowels not so much.
I would look at something like cascomite cleaning it of the face immediately. Also a plywood patress, drill holes (about 8) and countersunk either side of a centre line at right angles to each other in which to draw the two sides together once jointed.
As for Glue?
Cheers Ken will look into that
Nozzle
I've got three 36" clamps which should do the trick
This was my initial line of thought. Glue and then a strip of wood on the undside keeping in together.
Why do you not recommend dowels ? I have very little experience with woodwork so assumed biscuit joining requires an expensive router? I just saw you can buy kits like these https://www.screwfix.com/p/erbauer-biscuit-jointing-kit-47mm-4-pcs/65290 I'm wondering if these are as easy to use as the hand dowel jigs
I should have looked at the photo woops yes as someone already said clamp and glue and you can tap the joint with a block and hammer to get it just right
Dowel joining is never perfect, so better to have a more rustic look and let the planks fall wherever they fall, but it's a matter of preference.
Biscuit joining makes them perfectly aligned, but for one project i wouldn't spend money.
Unless you want to return the tool after using it which i strongly disagree with as it is immoral and maybe illegal...
you mean without the dowels just glue and clamps?
No I agree that is not something I would do. And yes, I don't really to spend too much money on tools I may not use again.
So you think ditch the dowels and just go with the glue and clamps?
