- Joined
- 19 Mar 2021
- Messages
- 7
- Reaction score
- 0
- Country
I was recently given a treadmill by an inlaw (dislocated my knee 6 month ago and can't run on the streets).
I've put it in my garage which has an old style breaker box which has HRC fuses 16amp for the ring and 6amp for the lights.
Says he moved the treadmill a few years ago and hasn't worked since. Power socket and switch were loose on it so that's where I started.
2 of the connectors had come away from the terminal so I connected them and tried it. Popped the breaker as soon as I press the switch.
I understand very little about circuits and earth leakage etc. I've tried switching the wires that were connected and it popped the HRC fuses for the ring as soon as I flipped the switch.
I've uploaded some images of the switch the wires available and the main board and motor.
I've read that carbon build up on the motor could cause an issue but the motor looks clean also the brushes have more than enough on them.
I've also tried plugging in the power cord into a surge protected extension with no joy. Just popped it again.
Any tips to fault find would be greatly appreciated.
