- Joined
- 18 Mar 2021
- Messages
- 9
- Reaction score
- 0
- Country
Would any of you kind folks help me discover why oil is not reaching my boiler's burner nozzle?
Is there a surefire way to check an oil pump is functioning?
Following running out of oil, I fired up boiler and it went to lockout.
The fan starts, motor starts and the motor is going round as I took the pump out to check.
Oil is present at the pump and with the bleed valve open, oil spurts out of the bleed valve when the boiler is fired up, but not when it isn't running.
Oil is not reaching the nozzle, but is reaching the bleed point on the burner prior to heading out to nozzle, as when the hex screw is turned oil flows until lockout.
Sparking is fine at electrodes and nozzle is not dirty, so I assume it's not blocked.
The coil on the solenoid seems to be ok as it grabs a screwdriver well.
I'm thinking the pump is the issue or the coupling to the motor?
Any ideas how to progress this fault finding to discover if it's my pump or the coupling.
Many thanks
Many thanks
