Seemingly quite possible.I've certainly seen wooden power poles with a copper strap running down the side and going into the ground, in this semi-rural area. To me, it would make sense that they were the "M" in PME
Not yet, hopefully on Friday, when back homeOP
Have you managed to get a gander inside another flat in the block?
As I've said, "PME" is a characteristic of the local LV distribution network, not of how consumers (or their electricians) chose to earth their installations. I think it's probably terminologically correct to say that I have a 'PME supply' but a TT installation.
when I had a house with a 1920's supply cable in outer London, looking like the OP's, there was a wound-on steel "bandage" armour (which went rusty in the ground, might originally have had bituminous paint), and a bituminous cloth bandage, inside which was a lead sheath with two conductors (I have an idea they might have been wax-paper insulated).
An electrician had previously incorrectly put a pipe clamp on the armour, but when a new meter was fitted, the iron service-head was replaced with modern grey plastic, the fitter stripped back the armour and put an earth clip on the lead sheath. I had an idea they would change it to PME, but I don't think they did. I wrote and asked if they would, and they said yes, but only if I had an EICR done first.
I think the iron head originally provided some kind of earth as it must have clamped the steel armour and the lead sheath.
Oh dearHad a visit from a UK Power Networks engineer today .... But when he was bonding my earth I asked him what type of earth it was, TN or TN-S or TN-C-S or something else, he replied "it is a standard straight earth"...
Indeed so - which is why I asked the OP what he was describing by 'bonding'. As you imply, it probably was not 'bonding' in the electrician's sense.The definition he was using may not be what we as sparks understand it. Bonding could be the general definition: ....
Quite so - I think we're all in that position.His reply "straight" could refer to the cable type, but for the fact that the supply cable feeding your flat isn't straight concentric cable. I'm not sure what he means.
It would - but I'm certainly not holding my breathIt would be very interesting to know the Ze.
