Fair enough, but for any of the sort of applications we're talking about you're never going to need a higher PIV than 400V. Even if the back EMF were very high, that's in the forward-conducting direction, so the PIV is irrelevant and, when used for this sort of purpose, the highest 'reverse voltage' it would encounter would be that of the supply - 12V/24V/whatever.Ok thanks @JohnW2 to be fair I have enough 4004 for my needs so im gonna get a few 4007 as there less than a couple a quid, scanning the net 4007 appears to be quite commonly mentioned for maglocks ( though I respect what you say about unnecessary in most cases) ... I can at least add them to increase my range of Electronic bits I have for Fire alarm repairs and the like.
He must be having a very atypical day, since winston is correct again As BS3036 says, the first character of that ("JEDEC") semiconductor naming system is a number, one less than the number of wires/connections - hence 1 for a diode, 2 for a bipolar transistor/FET and 3 for a dual-gate FET. The second character is always an "N". You must have come across transistors with 2Nxxx or 2Nxxxx numbers, haven't you?Out of interest I called them "IN4xxx" ( as it was hard to read off the diode) as did you, or was you patronising me but Winston called them "1N4xxx" as do the Ebay listings, so what are they
