Do you carry a first aid kit on the job?
A roll of Clingfilm is worth having close to the official first aid kit as it is a near perfect covering for burns. Then cool through the clingfilm
EDIT
Only applies for heat burns, do not use cling film on chemical burns as that will keep the corrosive material on the burnt area and thus prevent flushing of the wound,
But before applying the cling film runn off at least 3 turns then you won't be applying bacteria that may be on the outside of the roll to the wound.
I use Yellow 77 cable lube, before I discovered that I used Asda errrrm naughty lube
