From what (little) I know of these things, my personal answer to those two questions would be "You almost certainly won't know" and "Who knows?" respectively. Others may have more useful answers!My new CU (Wylex) has an SPD fitted next to the main switch. How will I know if it activates? Will it need to be replaced if it does?
If it has some sort of 'indicator' one could do that, but do they all (have indicators)? Even if they do, I would also imagine that it might well be possible, in some circumstances, for them to 'blow up' without the indicator 'indicating'?I assumed they eventually change colour and some you then just plug in a new module
Do you feel that there is a chance they could "Blow up", John.If it has some sort of 'indicator' one could do that, but do they all (have indicators)? Even if they do, I would also imagine that it might well be possible, in some circumstances, for them to 'blow up' without the indicator 'indicating'?
You won't.How will I know if it activates?
No.Will it need to be replaced if it does?
Well, I wasn't necessarily thinking of bangs and smoke, but rather sufficient internal damage to mean that they no longer cable of functioning as intended.Do you feel that there is a chance they could "Blow up", John.
All true, but 'the old days' were a long time ago. Although SMPSUs are undoubtedly proliferating, they have been around for decades, and countless (millions) of them have been around for very many years.John Ward did a video ... To cut it short what he says is switch mode power supplies and the like have semi conductors before the transformer where in the old days it was after the transformer and the transformer reduced the effect of spikes.
We (at least I) are not only guessing about whether SPDs will 'help', but also about whether the theoretical effects of 'spikes' arev actually mirrored by a significant real-world problem (that needs a 'solution'). As you will be aware, I am personally far from convinced - although I would be happy to change if someone could provide me with some 'convincing evidence'.The problem is we are guessing as to if they help or not ...
Also if every home has SPD fitted each home will assist in removing the surge, so in a street with all new builds each with SPD one odd home without it is less likely to have a problem to where yours is only home in the street with it fitted.
Unfortunately due to the current Uk regs this term is going to be used a lot from now.It is extremely annoying when an acronym (such as SPD) is posted without any explanation as to that which is meant.
From the context of this thread I have deduced that SPD may mean "Surge Protection Device".
Fortunately, sites such as https://acronyms.thefreedictionary.com/SPD are also of some help in this regard !
As has been said, it's unfortunately the case that anyone with an interest in 'electrics' who is appropriately participating in a 'UK Electrics' forum will very soon, if they don't already (which many/most do), know only too well what "SPD" means - and I imagine that the same will become true in your country if/when the "it is technologically possible, so let's make it a requirement" brigade show their faces nearer to your home.It is extremely annoying when an acronym (such as SPD) is posted without any explanation as to that which is meant.
