I'm sure that you are not aloneIt's a single user unit with 1 pc, security stuff and a telephone. ... I don't think we are bothering.![]()
Kind Regards, John
In the context of this thread, I personally don't think there is anything remotely obvious about what "properly" means.What else can’t you be bothered to do properly?
I find that this is exactly what every single electrician I have ever worked with does.It’s penny pinching. Working to the absolute minimum standard that can be got away with.
I'm not sure whether your comments relate specifically to matty's (commercial) situation, or are meant to be more generally - but mine were certainly intended as 'general', particularly in relation to domestic installations (in this DIY forum).It’s penny pinching. Working to the absolute minimum standard that can be got away with.
There were -There were lots of people moaning and refusing to install those new fangled and completely pointless RCDs when they first came out too.
Very true - but, at least speaking personally, it's nothing to do with money. If I perceived a need, I would have them - and, as I said before, I do not think that deciding that I don't have a need constitutes 'lowering my standards'.It’s a general statement. Domestic SPDs can be picked up for £20. That’s nothing on the cost of a CU.
... since, if "required" means "required because of a need", then I really do 'wonder', particularly in relation to domestic installations.Required in almost all installations.....
Well, you probably know some of my thoughts about thatThere were lots of people moaning and refusing to install those new fangled and completely pointless RCDs when they first came out too.
I think there's a far greater amount of Electrical equipment in Homes and Businesses these days that are far more susceptible to damage by Surges on Networks.
I think most of us, at the very least, "question the need" for SPDs, but the regs do now require them for many situations - and TBH for many installations it's going to be more hassle and time (i.e. cost) to work out whether the rules allow them to be omitted than it does to include them in a new install. I would not suggest retrofitting them unless a) there was a perceived problem that they might solve, or b) there's sufficient work being done as to make the current regs apply to an old installation (in the same was as we don't have to retrofit RCDs, but if we add a new circuit/extend an existing one such that the new work does need one then it makes sense to fit it in the board (if possible).As far as I am personally concerned, in relation to domestic installations, these devices are probably 'solutions looking for a problem'. As I asked before, why are some people now so keen on SPDs in domestic CUs when many of us were (and probably still are) usually describing 'surge protection' extension leads etc as being a waste of money'?
Let me correct that for you, "that could be susceptible should be already integrated with appropriate surge protection". As I pointed out in an earlier post, while that may be true buying genuine stuff from a reputable manufacturer via official channels - once you start looking at the the likes of eBay etc, then all bets are off (except my money would be on a lot of it NOT having the required protection). Heck, so much of it doesn't even have the right size pins on the plugAlmost all appliances that could be susceptible are already integrated with appropriate surge protection - it's basically mandatory in order to pass the surge and electrical fast transients testing during EMC compliance.
You may well be right, but that doesn't make me any happier about a regulatory requirement for something which I personally believe is, in the great majority of cases, unnecessary.I think most of us, at the very least, "question the need" for SPDs, but the regs do now require them for many situations - and TBH for many installations it's going to be more hassle and time (i.e. cost) to work out whether the rules allow them to be omitted than it does to include them in a new install.
Clearly sensible if there really was a "[reasonably] perceived [significant] problem that they might solve", but I suspect that would be a very rare situation. In all other cases, as above, I would not be particularly happy about a regulatory requirement for something which I personally believe is, in the great majority of cases, unnecessary.I would not suggest retrofitting them unless a) there was a perceived problem that they might solve, or b) there's sufficient work being done as to make the current regs apply to an old installation (in the same was as we don't have to retrofit RCDs, but if we add a new circuit/extend an existing one such that the new work does need one then it makes sense to fit it in the board (if possible).
I'm not at all sure that I would support a regulatory requirement which existed to prevent sub-standard and/or illegally-imported products from being damaged!Let me correct that for you, "that could be susceptible should be already integrated with appropriate surge protection". As I pointed out in an earlier post, while that may be true buying genuine stuff from a reputable manufacturer via official channels - once you start looking at the the likes of eBay etc, then all bets are off (except my money would be on a lot of it NOT having the required protection). Heck, so much of it doesn't even have the right size pins on the plug![]()
