- Joined
- 23 Nov 2021
- Messages
- 2
- Reaction score
- 0
- Country
Hello,
We have a robust, relatively new hot water & central heating system including a hot water tank and a system boiler.
We live in a fairly rural location and unfortunately experience power cuts quite regularly. In January this year, we had a power cut which resulted in a failure in our heating system (the hot water was working perfectly!). A British Gas friend determined that the heating valve was not responding when the heating was switched on. However, when forcing open the valve, the heating would work but ONLY when the hot water was firing up the boiler. Eventually a plumber came and fit a new heating valve which seemed to fix the problem. Only a couple of months later, the same thing happened again. A power cut resulted in our heating not working. We have lived with it for a while now but as the weather is getting colder, it’s just not heating the house up (as the hot water tank obviously heats up fairly quickly, therefore by the time the radiators are warm, the heating stops when the hot water stops firing the boiler.)
Id love to know if anybody can elaborate on why this is happening? Is there any way to prevent it in cases of future power cuts? Would it help to get an isolator switch with a fuse for the heating system? Any help would be much appreciated.
Thank you!
Thank you!
