- Joined
- 17 Oct 2018
- Messages
- 101
- Reaction score
- 8
- Country
Hi all,
Had a new sink fitted, kept the tap in the same place but now have the draining board on the right hand side.
The socket and fused switch are horizontally less than 30cm from edge of draining board. I assume it's now against regulations? If so, can the fused switch comply with regulations by being mounted 25cm to the right of draining board edge and up the wall near the ceiling? Is there a minimum height in this scenario or does only the 30cm horizontal rule apply?
Alternatively, can the fused switch be mounted under the worktop, on the wall at the back of the open cupboard and still comply with regulations?
