I need some advice from you guys on tiling. Never done it before and need to tile the floor of both utility and w.c area. My builder said tile the W.C before he fits it.
Couple questions:
1. Where do I start in terms of layout I know normally you start from the centre of the room but here there is two rooms with a door seperating so where do I start the run?
2. Should I fit door linings and tile up to them or just tile to studwork and then fit door linings?
3. Should I tile completely wall behind the toilet? Bearing in mind there will be a toilet unit sitting there.
4. Dining room is going to have different flooring /tiles and it's not yet known what we are going to use. How should I finish where the doorway is leading to the dining room?
Thanks in advance!
Couple questions:
Thanks in advance!
