Flashing lamp
But that is for if you wire it off the ring. You don't need it for a lighting circuit.
It seems that you are critical of any procedure suggested to connect loads other than lights to 6A circuits.
So what method would you suggest as good practice to provide total isolation for maintenance purposes without losing the light to be able to do the work?
Manufacturers requirement, cannot be by passed
Yes it can if, as is so often the case, it is wrong. There is no requirement in the regs to follow manufacturers instructions.
How would people fitting this outside the UK fare where FCUs are not available or complaint?
Have you never heard of a double pole switch?
In your opinion. Common sense clearly shows overloading a circuit by over 100% is bad practice.
It's impossible to overload a correctly designed and installed circuit, even if it contains devices of a higher rating.
