Hidden Gutter with ventilation
23 Jun 2018
Hi, The wall is built against the boundary and I should not be overhanging the gutter, hence require gutter flush to the wall. Unfortunately I'm unsure how its done.
I know sometimes square gutters made from ply and lined with lead are used or use of an aluminium square gutter. I was wondering if a plastic gutter would work in my scenario. I could built the outer wall up, add a 'L' shape length of ply to cover the cavity and fit the gutter on top ?
Ideally, I would like to build in some over facia ventilation, though I've been told tiles don't necessarily require ventilation.
I want to avoid a parapet wall.
I've added two images to show the current situation. At the moment the outer wall is lower than the inner wall and the joist need to be cut down. Would appreciate some ideas please.
a warm pitched tiled roof is possible
you need some sort of eaves support tray to keep the ventilation space
Id guess you will need to cut your rafter feet back flush close to the wall plate -if you fit a fascia to the wall plate you should be able to get a square gutter in there
obviously you need to set out your tile battens and tile eaves detail to suit
Hi, I'm working on a vaulted ceiling.
Currently I was considering, what I think is a cold roof (air gap above insulation), though I like the idea of a warm roof as it mostly eliminates the need for venting. If I stick to the original plan (cold roof) then I'm proposing to build as this illustration. Does this sound about right?
with a warm pitched tile roof the felt is fitted on the rafters a normal, then there are battens fitted on top, running in line with the rafters
then the tile battens are fitted
then anything from the top of the rafter down needs no ventilation.
that enables the venting to happen above the gutter -which might help you if you have no soffit to vent into the rafter space like a conventional cold roof
but it needs properly detailing
if you go to the dupont / tyvek website there are various construction detail options for cold and warm methods
