I've been used to using combi boilers with instant hot water previously.
This house has the set up as shown in the photos + 2 tanks in the loft.
I pressed the "heating advance" button assuming this would turn on the CH. However the pipes leading in to the cylinder were getting warm also, it heated up the water. Is that usual when pressing the "heating advance" button?
All of the radiators got warm apart from the downstairs living room which was still cool at the bottom.
Does the red grundfoss pump appear to be on the correct setting? Also the grey Drayton block with W, M and H on the side- what does this do?
I noted that turning the roon thermostat dial had no impact on the boiler being on/off.
Could anyone help with the this system please? Seems a bit more to it compared to the combi set up I've been used to.
Thanks.
Thanks.
