Unlikely ofgem is confused.I think you may be confused between storing and forwarding the data every 30 minutes and actually forwarding the data every 30 minutes.
The cost of the smart meter installation program was initially said to be 11 billion pounds paid for by a surcharge on bills; it has risen since then.Eh? Over what period of time? My entire total mobile phone 'usage' bill is only about £180 per year.
For a start, as Harry and I have said, at least at present it seems to be one call per day, so, at least at present, you can divide your figure by 48. In addition, it's ridiculous to believe that suppliers will be paying at 'mobile phone rates' for the calls - they are probably paying 'peanuts', particularly given that each call probably only has a duration of a few milliseconds, if that.2 calls/h * 24 * 365 = 17520 calls per year.
Seem the situation is worst than thought. If you are paying £600 a year now. By the time they roll out the full deal, you need to x48 that.For a start, as Harry and I have said, at least at present it seems to be one call per day, so, at least at present, you can divide your figure by 48.
Phone companies charge 35p set up charge per call, with the call cost on top. So an all inclusive 3.4p/call to the energy suppliers is about right.
It seems he's right - but the change to a default of half-hourly uploads is, as he said, not until 2025. However, I still don't see how the current infrastructure could cope with that - >2 billion calls per day is an awful lotI agree, but highly likely DiyNJ is confused.
I don't know where that £600 comes from. It's inconceivable that one call per day could cost remotely that much.Seem the situation is worst than thought. If you are paying £600 a year now. By the time they roll out the full deal, you need to x48 that.
Try telling a phone company that you want a contract for 2 billion calls per day, and ask if they would charge a 35 p set up charge for each of those calls, let alone an additional 'call cost' - i.e. around £250 billion per yearPhone companies charge 35p set up charge per call, with the call cost on top. So an all inclusive 3.4p/call to the energy suppliers is about right.
I use 2 IHD's, one for Octopus and the other for my Drayton Wiser heating system. The Octopus IHD gives me real time information but the Octopus app is a day behind for some reason. The Wiser IHD is in realtime too and the information presented on my Wiser app is also in realtime.I think you may be confused between storing and forwarding the data every 30 minutes and actually forwarding the data every 30 minutes.
I have specifically requested 30 minute data. I get readings for every 30 minutes, but never is the data current - it is always the following day, if I am lucky, though sometimes the data can be three days behind, suggesting the data has simply failed to get through, or the network too busy.
We've explained why. Although a smart meter stores half-hourly usage data, at present most only upload that data once per day - and the app can only see data which has been uploaded - hence anything up to a day 'behind'. The IHD, on the other hand, is seeing the stored data, before it gets uploaded.I... The Octopus IHD gives me real time information but the Octopus app is a day behind for some reason.
I'm not familiar with that system, so can';t say much. However, if the app is shoeing real-time data, that imnplies that wherever the appis getting its data from must be updated in more-or-less real time.The Wiser IHD is in realtime too and the information presented on my Wiser app is also in realtime.
I've also heard of such functionality, although I don't know whether the comms modules in basic 'smart' meters can do it, or whether some sort of add-on (or special comms module) is required.I read somewhere that a meter tries to get directly online, but failing that it talks to its neighbour, which passes on the data.
That makes sense. Since the meter cannot itself communicate with the "Wiser cloud", that cloud can only get data via the IHD - which, like the Octopus one, gets the data in real time directly from the meter.With Wiser the IHD gets its info from the smart meter and transmits it to the Wiser cloud over the internet, my Wiser app is connected to the Wiser cloud and gets the info almost immediately (within 30 minutes).
Which is nigh on impossible if the "code protection" bit has been turned on in the meter's micro-processor.You'd obviously need to extract the firmware,
