- Joined
- 11 Sep 2007
- Messages
- 942
- Reaction score
- 11
- Country
If the burner is encased in a tin box, it sounds like you have a balanced flue, bringing in combustion air from the outside.
By all means run the burner without it.
It is possible to test a capacitor with a multimeter but I haven’t done it so do check out YouTube?
Faulty capacitors can feel swollen or be black at the wire end, but that isn’t conclusive. Check the capacitor disconnected from the motor.
Oil pump solenoid coils do fail, look for an open circuit immediately the burner locks out......Diamond replacements are best.
The EBi is the igniter transformer, failure is possible and I have found that they can take out the Tf too!
Did you find the allen grub screws I was blethering about?
John
I do find that without the tin box it's a bit more smelly (as in a slightly sooty smell) but I'll see how it goes without it. Why don't they make it easier to remove (with no chance of knuckle-scraping and less effort involved?).
Noted re the capacitor. Think I'll skip that though, looks tricky to get out and I don't want to make the boiler worse. This particular cap LOOKS okay.
Where am I looking for an open circuit if the burner locks out? Do you have any details please or can maybe point me to a suitable online guide?
Is the EBi easy to test in circuit or does it need to be removed?
Yes, I can see the Allen grub screws.
