Whats confusing here John is OP said the throttle worked as it should on the donor mower before he swapped engine(Many makes of mower have a fixed speed engine, and no throttle control so this isn't unique.)
John![]()
Yes,So you mean this one.
Maybe the original engine had a variable speed throttle, whilst the new one is a fixed speed type?Whats confusing here John is OP said the throttle worked as it should on the donor mower before he swapped engine
Thats why I suggested removing it just to testIf that spring on the top of the quadrant was more relaxed, maybe it wouldn't be pulling the throttle butterfly onto full bore?
John![]()
This thread is getting very long its hard to keep going back to reference but I think op said hed tried with carb off donor as wellMaybe the original engine had a variable speed throttle, whilst the new one is a fixed speed type?
we don't know the history of the replacement engine, of course.
John![]()
Id put money on it JohnI'm wondering if someone has moved the governor arm in relation to the governor itself, inside the engine.......it's just held by a pinch bolt?
John![]()
www.diynot.com
